It does the same thing essentially, but without the need for grub screws. By running the eccentric nut down to the head of the bolt, then using a nylock to attach the bolt on the other side, it gives you the freedom to adjust the eccentric nut without it also having to mechanically hold the bolt in place. That job goes to the nylock nut.
