I had not homed my machine in a while and figured time for a calibration. I initialized the homing function and knew immediately something had changed. From start to finish I bet it was 40 minutes to home this thing. Not sure what happened somewhere but I recall the last time I homed the machine it look no longer than 3 minutes. Anybody else have this happen? It crawls at a painfully slow rate.
The rates that the machine will travel during a homing cycle are controlled by the grbl parameters. If you have upgraded your firmware, you might need to adjust the grbl parameters.
