You can use X-loader to flash a .hex file into the Arduino. Do you need special compile options or just a fresh copy of grbl?
Related topics
| Topic | Replies | Views | Activity | |
| Reseated G Shield to Arduino and only Z Limit switch works | 2 | 2170 | December 16, 2015 | |
GRBL V1.1 master release
25 | 26730 | December 28, 2016 | |
| If I replace my Arduino, which version of grbl to use? | 8 | 3105 | May 5, 2018 | |
| How to reload pre-loaded Grbl firmware to X-Carve Arduino | 3 | 4382 | June 19, 2015 | |
| [Solved] I'm stuck here | 7 | 2892 | July 30, 2015 |
