Edge lit topo map on acrylic
Trying to do an edge lit STL topo on !/4 inch acrylic using a 90 degree diamond drag bit, am currently starting with the finish path set to 2MM doc if anyone else is trying it, would like to know the best way to deal with the surround, am using Boundary relief 2mm depth 0.5 mm padding and 2mm Z position. Have been all day trying to come up with settings that make sense
