# Blowing up Easel. Help
**URL:** <https://community.inventables.com/t/blowing-up-easel-help/48041>\
**Category:** Projects\
**Created:** [December 31, 2017, 3:52am UTC](https://community.inventables.com/t/blowing-up-easel-help/48041 "2017-12-31T03:52:31Z")\
**Posts on this page:** 14\
**Page:** 1
<div class="post-metadata">
**Author:** ![MichaelLaviolette](https://yyz1.discourse-cdn.com/flex009/user_avatar/community.inventables.com/michaellaviolette/32/49925_2.png) [@MichaelLaviolette](https://community.inventables.com/u/MichaelLaviolette)\
**Post date:** [December 31, 2017, 3:52am UTC](https://community.inventables.com/t/blowing-up-easel-help/48041/1 "2017-12-31T03:52:31Z")
</div>
[EAGLE & WOLF Finish 1\_16 ball.gcode](https://cdck-file-uploads-canada1.s3.dualstack.ca-central-1.amazonaws.com/flex009/uploads/inventables/original/3X/0/8/083d0fe3f56c091a7bc2d1cc1464fbf29d70cf78.gcode) (7.6 MB)
Hi again all Noob at it again…
Ok so I wanted to try cutting this is MDF using a 1/8" endmill rough cut the using a 1/16" ball nose finish. When I try to bring the Gcode into Easle it validates the rough cut the starts saving and resets to a blank project. Not sure what I did different the MDF is 17"x17"x 3/4 thick. I restarted computer before bringing up Easle to clear the memory.
**Post date:** [December 31, 2017, 3:54am UTC](https://community.inventables.com/t/blowing-up-easel-help/48041/2 "2017-12-31T03:54:13Z")
</div>
It won’t even let me upload the rough gcode for this file to this post.
**Post date:** [December 31, 2017, 4:25am UTC](https://community.inventables.com/t/blowing-up-easel-help/48041/4 "2017-12-31T04:25:32Z")
</div>
I created it in Vcarve pro. I changed the 1/8" end mill to a 1/4" and it seems to run better in Vcarve.
**Post date:** [December 31, 2017, 4:29am UTC](https://community.inventables.com/t/blowing-up-easel-help/48041/6 "2017-12-31T04:29:58Z")
</div>
Was just going to try it in Easel with the 1/4" end bit.
**Post date:** [December 31, 2017, 4:32am UTC](https://community.inventables.com/t/blowing-up-easel-help/48041/8 "2017-12-31T04:32:28Z")
</div>
I was saving them as a separate Gcode. Rough and Finish shouldn’t be a tool change that Easel sees.
**Post date:** [December 31, 2017, 4:38am UTC](https://community.inventables.com/t/blowing-up-easel-help/48041/10 "2017-12-31T04:38:05Z")
</div>
For some reason it doesn’t like the 1/8" end mill Gcode it wouldn’t even let me upload it to the forum.[EAGLE & WOLF rough 1\_4 endmill.gcode](https://cdck-file-uploads-canada1.s3.dualstack.ca-central-1.amazonaws.com/flex009/uploads/inventables/original/3X/6/f/6fc1c8b4a831c22dcedf927768ce2a37636e53df.gcode) (6.4 MB)
Not sure what your asking I make it in Vcarve save the Gcodes the bring the Gcode up in Easel. Run it on Xcarve with the X-controller.
**Post date:** [December 31, 2017, 4:46am UTC](https://community.inventables.com/t/blowing-up-easel-help/48041/12 "2017-12-31T04:46:40Z")
</div>
Sorry Xcarve inch Gcode
**Post date:** [December 31, 2017, 5:03am UTC](https://community.inventables.com/t/blowing-up-easel-help/48041/13 "2017-12-31T05:03:57Z")
</div>
I had to of done something wrong when I have the 1/8" end bit in. I went in and changed the 1/8" to a 1/4" end bit and it is running fine. The size of the 1/8" gcode file is 147 MB the 1/4" is 5.49 MB.
**Author:** ![BrandonHurst1](https://avatars.discourse-cdn.com/v4/letter/b/3e96dc/32.png) [@BrandonHurst1](https://community.inventables.com/u/BrandonHurst1)\
**Post date:** [December 31, 2017, 2:53pm UTC](https://community.inventables.com/t/blowing-up-easel-help/48041/14 "2017-12-31T14:53:40Z")
</div>
You can get a post processor for V-Carve from inventables website here [https://www.inventables.com/technologies/vcarve-desktop](https://www.inventables.com/technologies/vcarve-desktop).
This is the one I use and it works perfectly have never had an issue.
Since I have started using V-Carve I only use easel’s GCODE feature.
The one annoying thing about Easel is having to reprobe the tool even if i’m doing re-cuts.
**Post date:** [December 31, 2017, 3:05pm UTC](https://community.inventables.com/t/blowing-up-easel-help/48041/16 "2017-12-31T15:05:26Z")
</div>
How to you bypass this step in easel?
**Post date:** [December 31, 2017, 3:06pm UTC](https://community.inventables.com/t/blowing-up-easel-help/48041/18 "2017-12-31T15:06:12Z")
</div>
I would only do this if rerunning a tool that just finished a cut.
**Post date:** [December 31, 2017, 3:07pm UTC](https://community.inventables.com/t/blowing-up-easel-help/48041/19 "2017-12-31T15:07:20Z")
</div>
I do that for X and Y but the Z probe is a different page that only shows probe or manual.
Do I click Manual? I have never tried that one.
**Author:** ![MarkA.Bachman](https://avatars.discourse-cdn.com/v4/letter/m/bb73d2/32.png) [@MarkA.Bachman](https://community.inventables.com/u/MarkA.Bachman)\
**Post date:** [December 31, 2017, 4:33pm UTC](https://community.inventables.com/t/blowing-up-easel-help/48041/21 "2017-12-31T16:33:51Z")
</div>
Yes on the manual choice you can select “use last home” which really means last work zero.
**Author:** ![JustinBusby](https://yyz1.discourse-cdn.com/flex009/user_avatar/community.inventables.com/justinbusby/32/30906_2.png) [@JustinBusby](https://community.inventables.com/u/JustinBusby)\
**Post date:** [December 31, 2017, 7:24pm UTC](https://community.inventables.com/t/blowing-up-easel-help/48041/23 "2017-12-31T19:24:53Z")
</div>
> [@MichaelLaviolette](#):
What is your pass depth? That is a drastically different size between the two.
And most likely Easel is barfing at the 147MB file. Just too big for Easel.
