Open Easel-Machine Inspector (CTRL+SHIFT+D)
Does it display an alarm state?
When homing the sequence is as follows:
- Tap Z-switch once, pull off 1mm then tap again at a slower rate (= double tap)
- Tap X & Y once, pull off and tap 2nd time
If these steps are completed you will be able to jog around/carve.
If these steps are not completed an alarm state will present.
