On trick I discovered for cutting thicker aluminum (1/4") try to make the cuts wider than a single bit witch if possible. I was having problems with runnout causing the bit to bind when cutting into deep channels. Switching form a outline cut to a pocket 40% wider than the bit, so it did 2 passes, make all the difference. Gantry Upgrade to C-Beam
