No machining today, I decided to finish off the stand for X-Carve and do the machining tomorrow after I clean up the sawdust.
Frame is 90x35 MGP10 pine studs, the legs are 90x45. There’s another frame that will go at the bottom of the legs and have castors mounted on it. There will be a shelf on the bottom frame.
The torsion box top is what the frame/legs are sitting on, it’s a bit more visible ion the second shot.
Here’s a shot of a finished bench for the 6040 CNC router. It also has a torsion box top.
