# 611 Router & Bearing Plate
**URL:** <https://community.inventables.com/t/611-router-bearing-plate/24250>\
**Category:** Uncategorized\
**Created:** [May 26, 2016, 10:55pm UTC](https://community.inventables.com/t/611-router-bearing-plate/24250 "2016-05-26T22:55:06Z")\
**Posts on this page:** 5\
**Page:** 1
<div class="post-metadata">
**Author:** ![MrNoone526](https://avatars.discourse-cdn.com/v4/letter/m/d26b3c/32.png) [@MrNoone526](https://community.inventables.com/u/MrNoone526)\
**Post date:** [May 26, 2016, 10:55pm UTC](https://community.inventables.com/t/611-router-bearing-plate/24250/1 "2016-05-26T22:55:06Z")
</div>
After assembling XC I ran setup & discovered that when router is lifted on Z-Axis, the yellow housing gets caught on the top bearing/shft plate & fails to lift fully to reach limit switch. Any1 else have this issue? Any help is appreciated?
**Author:** ![ErikJenkins](https://yyz1.discourse-cdn.com/flex009/user_avatar/community.inventables.com/erikjenkins/32/84368_2.png) [@ErikJenkins](https://community.inventables.com/u/ErikJenkins)\
**Post date:** [May 26, 2016, 10:57pm UTC](https://community.inventables.com/t/611-router-bearing-plate/24250/2 "2016-05-26T22:57:06Z")
</div>
Rotate the router a bit until you find a spot that clears…most of us had the same issue.
**Author:** ![DavidAnnetta](https://avatars.discourse-cdn.com/v4/letter/d/e9c0ed/32.png) [@DavidAnnetta](https://community.inventables.com/u/DavidAnnetta)\
**Post date:** [May 27, 2016, 6:42pm UTC](https://community.inventables.com/t/611-router-bearing-plate/24250/5 "2016-05-27T18:42:17Z")
</div>
Sanded it.
**Post date:** [May 28, 2016, 5:05am UTC](https://community.inventables.com/t/611-router-bearing-plate/24250/6 "2016-05-28T05:05:57Z")
</div>
Thanks for the quick replys guys!!!
**Author:** ![Chachin](https://yyz1.discourse-cdn.com/flex009/user_avatar/community.inventables.com/chachin/32/84631_2.png) [@Chachin](https://community.inventables.com/u/Chachin)\
**Post date:** [May 29, 2016, 6:26pm UTC](https://community.inventables.com/t/611-router-bearing-plate/24250/7 "2016-05-29T18:26:15Z")
</div>
Mine still interferes at the very top. I didn’t like the idea of grinding plastic off a brand new 611 router when I first built my X-Carve.
But now that the “newness” has worn off, I’m ready to bust out the Dremel…
Chachin…
